I’m using a Balance One Core with an AP One Mini access point. The AP One Mini is directly connected to one of the LAN ports on the Balance One. I also have multiple SSIDs (both through the AP One Mini for now) and multiple VLANs (the default untagged VLAN and another isolated VLAN) enabled. Should the Balance ONE LAN port connected to the AP One Mini be configured as an access or trunk port? Thank you!
Setting that LAN port as a trunk port is what you need since you have AP One Mini configured with multiple SSID on multiple VLANs.
