We are starting to roll out MAX BR1 MINI with WiFI and would like to try something.
Configuration will be
Firewall->BR1->Cell network
With IP Passthrough as the firewall will be performing VPN and possibly Static IP and other blocking.
What I would like to do is also setup a WiFI SSID that can connect to the public internet. The BR1 would provide DHCP to these devices.
And a second WiFI SSID that connects only to port #2 which will be connected to the LAN side of the firewall. This SSID would have access to the local LAN. The firewall will provide DHCP for this connection.
How much of this is possible? And any pointers on exactly how?
Thanks.
