I have an early BR1 Max (Product Code MAX-BR1-LTE-E-T). I have a replacement on order that is a MAX-BR1-ENT-LTEA-W-T.
Can I apply the config file from one to the other?
Steve
Steve
No, you can’t upload the configuration from BR1 to BR1 ENT.
BR1 have WIFI AP/WIFI WAN feature while BR1 ENT is not. Direct config uploading is not supported. Please contact Peplink local partner, they should able to help/advice on the device migration.
