Compatibility with other caching systems (like mikrotik)
Cache system integration
Despite plans for a product cache, still not possible any integration of other systems cache, PePLink. Because he does not have a rule or function like this:
Source: XXX.XXX.XXX.XXX / XX
Redirect to: XXX.XXX.XXX.XXX / XX
  • Disable if it fails: YES / NO
  • If the destination ip failure (no response ICMP) disable the rule
So we can redirect everything that passes through port 80 to the system cache in redirect to
The WCCP would be good, however has the licensing issues with cisco for integration. Currently do not have any way to integrate PePLink with some caching system.
:frowning:
