Compare old and new Pepwave config
Looking for a way to compare an older, saved Pepwave config with a newer one. Part of configuration management to verify we have only changed what we intended to change. You can save the config from a router, but not in a format that can be easily compared, as far as I can tell. Has anyone found a solution to this problem?
An easy way to do this is upload a saved configuration file to view each config but do not apply changes. You can simply discard changes from the dashboard.
Ron, thank you for the suggestion, but someway to do an actual diff of two configs that only showed the differences would be much better.
I agree. Such a functionality, perhaps in a command line tool, would be very useful.
Output could be in XML, HTML, or some diff format.
[edit: Peplink team, as this topic’s scope is bigger than just the Pepwave MAX, could you recategorize it as a Feature Request (for all relevant Peplink products) and also give it the configuration tag? Thanks!]
Moved to feature request.
