I have a Balance One that I’m trying to configure to connect to Comcast Business Gateway (NETGEAR CG300DCR) that is configured for 5 static IP’s.
I can configure the WAN ports 1 and 2 on the Balance One for the first two static IP’s and each port connects and passes DNS test.
I would like to map each static IP to a separate VLAN with a different DHCP address pool.
If I enable VLAN on the WAN port definition and assign it to a VLAN, the WAN port will no longer successfully connect to the Comcast Business gateway. I don’t see anywhere in the Comcast Business Gateway to assign a VLAN.
Does anyone have any experience successfully using VLANs with Comcast?
Thank you
