Hi all,
i have 2 balance 210 and 5 dsl internet lines , the question is " can i connect 3 dsl line to first peplink ( after licence) and then connect the lan port to the wan port of the seconed peplink with 2 dsl lines "?
i mean can i combine 3 lines in one peplink 210 after that connect it to the second peplink with the other 2 lines ?
Yes you can daisy-chain like this but you need to realize that the second Peplink will only “see” the first Peplink as a single WAN connection.
If all of these DSL lines are the same and you are trying to spread the traffic across equally then you should use the Weighted Balance algorithm. On the first Peplink give all 3 connections a weight of 10 and on the second Peplink use a weight of 9 for that connection and a weight of 3 for the other two connections.
