Changing handshake port
I have max hotspot, When I change the handshaking port from 32015 to 32020, it continues to use the original port “32015” for handshaking when it tries to establish the tunnel. Is this normal? what should I do to make it use the new port?
@Omar_Dehneh ,
Assuming you are changing the handshake port used by the remote device:
By default if you change the handshake port it should immediate take effect after the changes is applied.
Seeing that you have issue on this, please open a ticket for the support team to check on the issue.
Great. Thank you for your support.
