Change radios in MAX series cell router
I am looking to change the Sierra Wireless cell modems in a MAX BR2 with MediaFusion to match locations where these vessels will be travelling. Has anybody any experience with this?
You should get the correct model to work on your requirements. Detail info please refer to the URL below:
You can have the device model that can work across different regions
Hello @Devinder,
It is possible to get customised models made, though there is normally a MOQ (minimum order quantity) & you also may have customisation costs too.
Your local Certified Peplink Partner will be able to help you best.
https://www.peplink.com/peplink-certified-partners/
Most likely there is already a solution that will cover your requirements.
Happy to Help,
Marcus :slight_smile:
