I’ve enabled remote user access through my Max modem using the OpenVPN type (set in the Web Admin under Advanced → Remote User Access → VPN Type). I’d like the system on the other end to have a fixed IP address, but I think by default OpenVPN updates client addresses periodically (maybe every 6-12 hours). I think it’s normally possible to change the OpenVPN config to use static addresses (or at least update them less often), but I’m not sure if the settings are available through the Web Admin. Is there some way to access the OpenVPN config details? Thanks!
Alex
