is it possible to change the LicenseCode on a FusionHob Solo Instance but keep the rest of the Settings?
Best regards, Martin
No its not.
Currently you would:
Is it possible to exclude the WAN/IP-Settings from the Backup Config restore?
No. you would have to access the console of the vm and manually configure the WAN IP if it has been statically assigned.
