Change Cellular
Recently I installed an Pepwave Max-BR-E2D6.
Recently we were in Netherlands and the Pepwave logged on to Telemobile NL provider.
Now we are back home in Germany, 10KM from to German-Netherlands border.
When checking is find that the Pepwave still is connected to the Ducht Prvider, Telemobile NL.
What can I do to have Pepwave log on to a German provider ?
Do you have a local sim card from Germany? If you are using a Dutch SIM card, do you have Roaming enabled?
I have a German O2 Sim-card in Pepwave
If it’s a german SIM card, if you disable Roaming it should only connect to a German provider.
Does O2 have coverage there?
