[Case] M/Y Limitless
Challenges
The captain wanted to improve the data services for the owner, guests and the crew.
The vessel travels extensively year round in the Caribbean, USA and Europe. Using different carriers in multiple countries the routers ability to support this is a must.
Solutions
MAX HD4 LTE router is installed onboard M/Y Limitless in combination with 4 high-gain omnidirectional cellular antennas.
Benefits
Communications are encrypted and run over Peplink SpeedFusion bandwidth bonding VPN service, securing sensitive data and providing the ability to access IP sensitive services such as Netflix.
MAX HD4 with pre-loaded SIMs for multiple regions allows for easy switching when changing regions and gives the vessels data speeds up to 80Mbps downstream depending on carrier and location.
By using non-roaming SIMs HD4 is able to provide the vessel with 50 GB data bundles in Spain, France, Greece, Malta and Croatia and even unlimited service for Italy.
All external antennas are tucked away almost invisibly, delivering ultimate performance without disturbing the look and feel of the vessel.
Specification highlights
MAX HD4 LTE
WAN: 2x gigabit ethernet and 4x embedded LTE
LAN: 8-port gigabit ethernet switch
Supports redundant SIM slots per LTE (One SIM as active. One SIM as backup.)
DA 1264 world wide omni 9dBi antenna
Gain: 4-9 dBi
Impedance: 50 Ohm
Bandwidth VSWR: less than 1.5: 1 695-3000 MHz
Radiation pattern: omni directional
Times LMR 240 cable
Length: 43 feet
Impedance: 50 Ohm
Connectors: N/SMA connectors
DA 1264 world wide omni 9dBi antenna covering 695-3000 MHz in a compact design with UV stable polyurethane finish.
