OK. I have probably done wrong but am in a circle here. First, purchased a balance 380router and an AP enterprise. Easy. set it up. setup a portal on ONE of my SSIDs. Next purchased switches and more APs and deployed InControl. Problem is…my APs are “attached or managed” by my router. Thats not a problem maybe but my portal was wiped out because I created several VLANS by way of InControl. I can’t seem to add an SSID that is transmitted to the router and if I create one on the router it is wiped out by InControl.
HELP…
thanks
