Can't get SpeedFusion on MAX BR1 Pro 5G
I had a test fusion hub in AWS that expired and SpeedFusion had worked to the MAX BR1 Pro 5G. Was built late December 2024 from AWS marketplace. I built a new FusionHub a few days ago from the AWS marketplace instance and added 5 peers OK.
Now the FusionHub and MAX BR1 Pro 5G are up and can be seen ok on IC2 but the SpeedFusion connection is stuck at “starting” - failed to establish connection (failed to connect remote peer)
In addition the FusionHub and MAX BR1 Pro 5G have a connection back to a fixed IP old B380 where the SpeedFusion connects ok – B380 not on IC2.
Look at the Fusionhub details how many Peers can It support?
Does your BR1 Pro 5G have active primecare subscription?
If you disable the B380 tunnel profile on the Fusionhub temporarily does the BR1 Pro connect?
