Can not connect to LAN port on new Pepwav Max Mobile router
I have just received a new Peplink Max Mobile router and am unable to connect to the Lan port at ip:
http://192.168.50.1
I have set my laptop to:
IP: 192.168.50.2
Subnet: 255.255.255.0
Gateway: 192.168.50.1
If i try to ping it says unreachable … browser goes no where …
Anyone else ever had this issue?
I did not that Windows 7 shows this configuration as an Unidentified Network Location.
Any ideas would be appreciated :slight_smile:
SL
If the Pepwave Max is right out of the box it will be DHCP so no static configuration is needed. Please give this a try.
Originally I tried DHCP and that did not work.
So I moved to the static configuration.
I just completed a factory reset and now it is pingable and I have been able to log into with the configuration above.
So must be have been an anomaly.
Thank you for the response :slight_smile:
