I don’t need bonding, but I do like the ability to combine multiple cell modems into one single wifi signal. I do this now with a single max-on-the-go, but I was wondering if it is possible to plug two or more max otgs into a load balancing router?
So essentially, two OTGs with four USB modems, plugged into a load balancing router, and the router then has an wifi access point plugged into it (… so not using any of the wifi on the max otgs).
Alternatively, could I plug the 2nd max-otg into the 1st max-otg’s WAN port? And if so, could I daisy chain as many as I wanted going this route (e.g. combine four max-otgs by daisy chaining max-otgs via the wan ethernet port).
Is this possible, would performance take a hit? I know it isn’t ideal as the balancer really doesn’t know how each separate Max OTG is balancing.
Thanks!
