I am building a stretch virtualization cluster across two buildings, each with its own Peplink Balance, all part of our global Speedfusion network.
I am using a virtual router which will announce routes via BGP.
In normal operation, can I announce the same routes via BGP to both Balances - that is, one in one building and one in the other? Or do I need to ensure that only one building’s Balance sees the announcement at a time?
I know that having the same static local route configured on more than one Speedfusion node is not supported - but does the same apply if the route is learned dynamically?
