Can HD2 be used with BR1-Pro 5G
I am needing of advise if this is possible? We have a peplink BR1 with two sim cards however we would like to use all our available internet connections concurrently with speed fusion connect vpn. I was wondering if we will add HD2 Pro and starlink with a managed POE switch is this compatible to all equipment’s?
Short answer:
Yes, that should work (with a tweak, see below).
Longer answer:
We are testing a similar system with slightly different components:
Main router: B20X with two cellular connections, a virtual WAN and a “real” WAN.
Virtual WAN (VLAN 4) to a BR1 providing a third cellular connection.
“Real” WAN (the regular port) to a Max Transit Duo, synergized, providing two more cellular connections (and an additional WAN connection option which we did not enable).
Thus we have five concurrent cellular connections from the main router, with speedfusion combining them for redundancy.
For your architecture, swap the BR1 with your starlink.
The tweak:
In order to synergize the Transit Duo we had to employ the regular WAN port for its connection on the main router. The Virtual WAN port was not made available for synergy use by the admin interface.
Good luck!
Z
