Hi Team, just like we can check multiple devices warranty expiration dates, is there a way for us to be able to check their IC2 exp dates as well? This could either be built into the warranty checker or it could be a completely new tool.
Is this what you are looking for:
From the organization level in IC2 you get a table with devices and their respective Service Status and Service Expiration Dates (IC2 subscription and warranty)
Believe @TheMissingLink refer to Peplink partner pavilion portal. Please send your request to the following forum post (limited to partner only)
https://forum.peplink.com/t/partner-portal-waranty-report-ic2-subscription/15896
I see. Above my pay grade.
Hi Sit Loong, thank you. I will post it there.
