Just an FYI: After applying changes in firmware 6.1.0 build 1419 the yellow horizontal stripe at the bottom of the dashboard screen that says “Applying changes…” never goes away while positioned on the dashboard. If go to another page in the UI and then back to the dashboard, the yellow stripe is gone. Seems to be a page refresh issue.
Running on a Surf Soho.
Thank you for bug report. This issue will be fixed in coming firmware release.
Thanks, glad to hear.
