The change name via CSV file is broken if you are changing it from the ‘Organization Device Management’ level, it only works if you upload the CSV at the ‘Group Device Management’ level.
Is there any ETA when this will be fixed?
I have reached out to an engineer about this for further evaluation. Once we know more information an update will be provided.
It is fixed, please try again.
THANK YOU! Confirmed it is working now.
Could you please share an example of the file you pushed, I’m failing to get it to work on my end.
Kind regards,
Maciej
