BR1 WiFi WAN and AP simultaneously
Which MAX routers can work simultaneously with the WiFi WAN and the AP features in a complete independent band and channel?
Currently we are using these features with our BR1s and we have some problems with the AP when the WiFi WAN signal is weak. The AP switches off/on many times because both WiFi WAN an the AP must work in the same band/channel. For a LAN client this is very annoying. Is there any way to avoid this behavior of the BR1? Thank you.
BR,
Gorka
You would need a MAX HD2 or HD4 as these models have separate radios for the Wi-Fi as WAN and AP. The BR1 only has a single Wi-Fi radio and software magic let’s them both operate simultaneously. Thanks.
OK. Thank you Tim
