We are installing IP cams in a mobile unit. We have the BR1 max slim unit setup as the wifi wan connection to the clients network. The client network asigned the Slim an IP address through the wifi wan connection. This is where I need guidance. I believe the IP camera will plug into the LAN port on the slim and get an IP address from the LAN DHCP server of the slim. My question is this. How can I see the camera from the clients network? I’ve gotten a few ideas including port forwarding the WAN IP to the cams LAN IP . This was supposed to be a simple bridge but our purchasing people bought these units now I have to make them work. Please help
How many cameras on the LAN of the BR1 Slim?
Port forwarding will be the easiest way. Then you will be able to access the cameras using the IP assigned to the wifi WAN interface from the clients network.
Worked perfect. Thank you.
