I did use the search function but found conflicting info. I have a BR1 MK2 . I’m trying to figure out what happens if I put both the WiFi WAN and Cellular WAN as Priority 1 in the dashboard. Does the router leverage the bandwidth of both WAN connections?
Yes. You’ll get session based load balancing across any wan in priority one on a BR1
Thank you.
I have three WANs in priority 1 on a MK2. Outbound policy set to Fastest response. Once I get a stable 8.0.1 firmware (currently a bug present) I plan on testing Speed fusion.
