We have 500 or so BR1 MINI devices installed in the field. Is it possible to create a VPN to tie all of these together. We’d like to create a dashboard to be able to see the status of all our field devices that connect through the BR1 MINI to the web and would need a connection to all BR1 minis simultaneously.
Any advice is appreciated.
Thanks!
FusionHub will do exactly that. You can host it on AWS, Azure, Google, or even on-prem.
We are a peplink partner and can help you with this.
What is the use case? do you have equipment behind there you are trying to reach?
Feel free to reach me via PM or [email protected] if you want to share private information.
Hello @cellevator Cartor,
Have you contacted your local Peplink Partner from whom you acquired these 500 units? They should be your first point of contact for a suitable solution, as they should fully understand your business requirements.
Alternatively, there are several very experienced Peplink Partners that you can reach out to (such as @Jonathan_Pitts and ourselves); you can find prequalified Peplink Partners via the Peplink website https://www.peplink.com/buy/peplink-certified-partners/ if you need options.
Depending on the data requirements, you may need a physical appliance capable of Peplink SpeedFusion. Using a Peplink FusionHub has its place, though a proper assessment needs to be done before recommending the most suitable Peplink solution(s). Managing these with the Peplink InControl2 platform is usually the best combination. Peplink routers also support IPSec or OpenVPN if you have to use existing infrastructure.
Happy to Help,
Marcus
