Does anyone have a link or know where I can find a vehicle wire diagram for the Pepwave Br1 Mini.
what sort of spec are you expecting? A BR1 mini has a two terminal power connector (+ and - @ 12-28v DC) . So generally you can just wire direct into that from a switched power source in the vehicle, although I would typically add a voltage regulator inline because I like clean power to in vehicle MAX devices and I’d add a low voltage cut off to protect the starter battery if I’m powering the MAX from a single battery vehicle.
The only other thing we’ve started to do recently is put a 12v DC UPS inline so that if the vehicle is turned off for short periods (think delivery driver or bus that stops regularly) then the MAX stays connected and running on its own Li-Ion battery until the next time the primary power source is turned on (at which point the battery gets charged again).
