I am looking at a BR1 Mini with the LTE-A modem in it. My concern is the router throughput. Specs list it as 100Mbps. Isn’t this a bottleneck for WIFI as WAN and eventually LTE-A when carriers get above 100Mbps actual speeds? Or am I missing something?
Hi BSmont,
Keep in mind the BR1 Mini is a entry lvl device. At the moment getting 100MBPS on LTE-A is depending on your country and carrier +signal strenght. We have been testing with LTE-A on KPN in the netherlands and the max we could get 800M away with using correct antenna’s was 104Mbps (even tho we did use a higher model that should be capable of more). so it wont really cause a bottleneck yet as most carriers are keeping the Data-rate down to save bandwith in urban area’s.
Hope this is helpfull to you in some way ?
Hi @bsmontgomery1,
Personally I would’ve liked to see all Peplink/Pepwave LTE-A products with a CAT. 6 module (300 Mbps).
Unfortunatly this is not the case.
I’d advise you to take a look at the MAX BR1 ENT LTE-A or the Balance 30 LTE-A.
Both have router throughputs of 200 Mbps, which might fit your case more.
