Are the antennas for the MAX BR1 Mini are operating in MIMO mode or in diversity mode? So far I understood we have a diversity mode which means the 2nd diversity antenna is only to improve the reception of the signal by putting the antennas in a distance of n x apart from each other.
MIMO indicates a parallel transmission on both antennas.
I just purchased a MAX-BR1-MINI-LTEA-W-T, and I’m curious about orientation of the antennas, as it has two SMA plugs labeled Cellular Main and Cellular Diversity/Aux
I’m using the included antennas. What should I do?
Main oriented veritcally and diversity at a 90 degree angle (e.g. horizontal)?
Main at 45 degrees and diversity at 45 degrees (so there’s a 90 degree angle between them?)
This is what I do (purely for aesthetics as I like the way it looks) until the antenna hinges work loose and then I hot glue the hinges vertical.
Since the Aux antenna is receive only on a BR1 MIni and due to carrier aggregation will be receiving a different frequency that the main antenna you on’t need them out of phase.
