br1 max pro remote vpn to balance 310
HI ALL ,
how can I set up vpn connection between br1 mini max pro with the balance 310 Fiber 5g .
thanks .
all best regards .
First you need to provide more information regarding the connectivity you have for each device:
Will either device have a public IP addresses?
Will they have a static public address or dynamic?
How many connected will you have on each device?
Then you might get some advice on how to connect them.
