BR1 IP Passthrough
what’s the best way to configure the BR1 so that it passes wan IP to my router without NAT?
For the BR1 you can enable IP Passthrough in the WAN settings or you can also reach out to your point of sale to purchase a Drop-In mode license for the BR1, depending on your needs.
ok that part seems to work. But i still can’t access the devices with ports open on the other router.
any ideas?
Are you trying to come in over the cellular connection? If so you will need to subscribe to a static IP from the carrier. Thanks
