BR1-ENT : Does it support Japan GSM SIM Cards?
Hi Team,
Does anyone have any experience to advise if BR1-ENT is compatible with Japan GSM SIM cards?
We have a client who would like to bring 1 unit over to Japan to perform some POC trials.
I tried to look at the link below, but it seems to refer to USB stick modems
Thanks! :slight_smile:
Eugene Chee
Check out this website
GSM World Coverage Map- GSM Country List by frequency bands (tells you the frequencies used in each country)
I believe Japan has the same type of SIMs as the rest of the world? (Normal, Mini and Micro)
Hi GNO-2014
Thanks for the tip, I’ve tallied the specs with this web site and got a match.
I am also interested in using this Japan. However, it doesn’t seem like it is listed on your site.
This current thread seem to suggest it is supported from a technology perspective. Do you have any certifications that I can reference so I can use the product in Japan (FCC and others…)?
Hi @kenichiwa
Could you please send us a sales enquiry describing the details of your deployment and requirements? See the “contact us” form here: http://www.peplink.com/company/contact-us/
Our team will surely be able to help. Thnx.
Just want to follow up on this again…
Is it on the product roadmap yet to get the VCCI certification on Peplink products?
