BR1 5G will not re-connect wifi without rebooting
Everytime the WiFi goes down or out of reach, when it becomes available again the BR1 5G Pro does not automatically reconnect without rebooting the device. If I go and scan for new WiFi SSID’s it comes up empty until the reboot, as if the radio is off.
Has anyone else seen this behavior?
Running FW 8.3.0
Orlando
@odavis, I found that we had a case where the user reported a similar symptom (also BR1 Pro-5G), and we have provided him with a special firmware (8.3.0s191) which seems fixed it as according to the feedback.
You may want to try it out and let us know the outcome.
Thank you, I will give this a try and report back.
