Bonding RTMP
I want to be able to use my vmix laptop or my Yolobox Pro to livestream using RTMP protocol when in remote locations.
They both have wifi and RJ45 connections, If I use a UBR LTE and bond 2 cellular and 1 wifi signal from cellular modem as Wan using speed fusion and set a outbound rule for all traffic to use Speedfusion Cloud with all three cellular sources set to priority 1, can I livestream over this bonded connection using RTMP protocol. ?
Im not familiar with the UBR LTE itself, but i use my SFC to stream RTMP from my vmix laptop. Cant really get anything over 1080p 6000kbps bitrate
Thanks Adam - that will be more than adequate.
