Hi Guys
Got a strange one here, i have two HD4s both of which are on the same firmware (8.0.2 4407). When i go into status then monthly, one unit allows me to set a billing period, whilst this option is missing from the other one. Weird.
Screenshots below, anybody any ideas?
Many Thanks
Matt
Hi @RoamingExpert,
You need to set the bandwidth monitoring and select a refresh date. Once this has been applied, you’ll be able to use the billing cycle report.
From the Dashboard, select the WAN details button:-
Scroll down and tick the Bandwidth Allowance Monitor box - click ok to the warning message and then enter the refresh date and data allowance.
I hope this helps,
Steve
Hi Steve
Thank you very much. That had me very confused. Much appreciated.
Regards
This topic was automatically closed 182 days after the last reply. New replies are no longer allowed.
