BGP Export to OSPF Issue
Hi all,
I am looking for some assistance. I have a Peplink 1350 that had BGP running to a FWL. The FWL is advertising 4 routes 0.0.0.0/1, 128.0.0.0/1. 10.0.0.0/8 and 10.51.2.6/32 (mainly default routes) to the Peplink 1350 via BGP. I can see the 4 Imported routes on the Peplink. I have BGP routes being exported into OSPF for onward distribution to remote sites via SFVPN connections. However, the Peplink is not exporting all 4 of the routes. It appears to be only exporting 128.0.0.0/1 and 10.0.0.0/8 into OSPF. All routes are being sent to the Peplink 1350 with the exact same attributes from the FWL.
Has anyone come across anything similar. It was working fine up until yesterday and all of a sudden (despite no changes on either the Peplink or the FWL) it has stopped sending 2 routes into OSPF./
Any help or advice anyone can give me would be greatly appreciated,
Regards,
Nick Vardy
Did you check this box
with this option enable learned lan segment from bgp will be injected to OSPF (Speedfusion)
