What is the recommended WAN Health-check settings to use on the Balance One router for the attached MAX BR1 Mini in IP Passthrough mode?
Topology: MAX BR1 Mini (IP Passthrough) > Balance One WAN2 port
- there are 4 other WANS in use on the Balance One that are all VSAT links providing a public IP address via DHCP to the Balance One
The BR1 gives the Balance a private IP (192.168.50.x) until a cellular connection is established, at which time BR1 passes a public IP on to the Balance. I have the BR1 setup with the SmartCheck WAN Health-check and the Balance is set to use DNS lookup with default failure/success counts & interval.
The problem is that the Balance shows the WAN as connected and active the whole time, even when BR1 doesn’t have a SIM card installed and is providing a private IP address.
Is there a way to view the routing tables of the Balance One?
