Best Port to send through
I have two MAX700 with an AT&T and VZW sims installed and VPN up and running. I am attempting to use Teradek slice H.264 encoder and decoder on either side to communicate with each other.
I can set a static IP on the device and set the protocol to TCP. I have gotten a couple of frames of video over the connection but then nothing. The Teradek has defaulted to port 9710. Is there a better port to use on the MAX700HD2s?
Is the video stream being sent using multicast or unicast?
it should be unicast since I am sending from one encoder to one decoder
please open a support ticket here so we can take a closer look:
http://cs.peplink.com/contact/support/
