What would be the best setup of external antennas for my HD2 MBX 5G. Should they be all the same braND and style or could I mix and match.
Hi Joseph. The router is essentially agnostic vis-a-vis antenna selection. All the router “cares” about is the signal metrics – SINR, RSRQ, and RSRP. So, it’s fine to “mix and match” to optimize signal. Now the actual selection of antennas is another discussion and is highly location/installation dependent.
What type of location are you installing the device? A building/home? Mobile?
If its a fixed location you likely could benefit from directional antennas. If its mobile you need an omni antenna.
Its going to be mobile its in my RV
For the cellular connections a pair of Puma 401’s would work great!
ok well i just purchased 1 puma 421 to see how it goes
