Is there a limit on how much bandwidth you can fuse?
What device can fuse bandwidth upto 1TB?
Hi Kevin,
the answer is - It depends.
- Are you going to encryption or not ?
- Then for the device selection you can use these comparison tables to select the right Peplink router (Check the SpeedFusion VPN Throughput sections):
- Bonding needs two ends. SpeedFusion Connect will not suit as it will cap throughput to 200Mbps. So you will need to host FusionHub or use another Peplink router to do the bonding at the another end.
