Hi all,
I recently purchased a BR1 Max Mini LTEA as a backup router as my main one need to be replaced with something better (working on that). Anyway, I got it because it is CAT6 and with two signals aggregated it will work great at my home. I notice that I don’t seem to have a second band connected when I click on the WAN Connection Status.
Is there somewhere I need to set up aggregation, or should it just do it on it’s own out of the box? I am using the same WaveForm flat panel antenna that allowed me to aggregate great on my primary router.
Any hints would be great. Here is my current connection:
T-Mobile
LTE Band 25 (1900 MHz)
RSSI: -82dBm SINR: 8.0dB RSRP: -110dBm RSRQ: -14.0dB
I have similar dBm for the following bands:
2, 4, 25, 41 (also 66 and even better on 71, but I realize they are out of the capabilities of this little modem).
TIA!
