I just want to verify if the Router Throughput of Balance One is increased from 600/400Mbps to 1Gbps according to this page?
This is the official throughput supported by Balance One.
The page you accessed should be an old page.
I see…
So its 600/400Mbps.
The PORTS are at 1Gbps but the throughput is what @TK_Liew said. That spec has been in place for quite a while. - Rick
