Balance One PepVPN Mex speed
Considering the balance one has up to 5 WAN ports it seems odd that the max Speedfusion peer speed is only 60mbs.
Is this really the max aggregated speed possible? Or can additional licenses unlock faster available speeds?
Ah its because it’s a comparatively cheap box. VPN throughput limitation is due to available hardware resources.
If you need more throughput you would need a device with more processing power to cope with it.
Yes it is. Its a hardware limitation not a software one.
