Thanks, I will. I did a factory reset and seemed to be better for a few days but just happened again…this is costing me money and is very irritating…it came back after like 5+ minutes…I was able to get the WebAdmin login screen once but wasn’t able to log in and then got this message (below) and then was finally able to login a few minutes later…
/1.1 200 OK Server: nginx Date: Thu, 30 Aug 2018 18:07:46 GMT Content-Type: text/html Transfer-Encoding: chunked Connection: keep-alive Set-cookie: pauth=G76WMp2xm9p6Ao1z42o4U24ZvrIbDyslzzbbX5Ghd7eEu; HttpOnly Pragma: no-cache X-Frame-Options: SAMEORIGIN 19a3 <!DOCTYPE html> <html> <head> <meta http-equiv=“Content-Type” content=“text/html; charset=utf-8” /> <meta name=“apple-itunes-app” content=“app-id=582215646, affiliate-data=, app-argument=”> <meta http-equiv=“X-UA-Compatible” content=“IE=Edge”/> <link rel=“shortcut icon” href=“connicon.cgi?type=favicon”> <title>Web Admin | Welcome</title> <link rel=“stylesheet” href=“…/…/default.css?$Name: 2018/01/25 13:34:21 $” type=“text/css” /> <!-- jQuery UI - Style Sheet –> <link rel=“stylesheet” href=“…/…/jquery-ui.css?$Name: 2018/01/25 13:34:21 $” type=“text/css” /> <link rel=“stylesheet” href=“…/…/jquery-ui-custom.css?$Name: 2018/01/25 13:34:21 $” type=“text/css” /> <!-- Custom Styles–> <style> body { font-family:Arial, Helvetica, sans-serif; font-size:inherit; padding-top:0.1px; margin:0; } #warning { margin:110px auto 10px; padding:30px; width:300px; background:#FCC; color:red; font-size:12px; } #login_box { position:relative; margin:80px auto 0; padding: 160px 50px 0 300px; width:484px; height:300px; background:url(“connicon.cgi?type=login_screen”) no-repeat; } #login_box > div { margin:0 0 10px; } #login_box > .smart_status { max-width:300px; }x; }gin_box > .notif_box, #login_box > .company { position:absolute; left:19px; width:776px; } #login_box > .notif_box { top:18px; padding:10px 10px; background: black; border-radius:10px 10px 0 0; height:89px; color:red; font:700 24px Arial, Helvetica, sans-serif; text-align:center; } #login_box > .company { top:392px; padding:5px 10px; background:#E9F1FC; border-radius:0 0 10px 10px; font-size:9px; } #login_box input.text_box { width:200px; } #login_banner { padding:5px 20px; font-family:“Courier New”,monospace; font-size:18px; font-weight:600; color:#F33; background-color:#FEA; } </style> <!-- jQuery + jQuery UI –> <script type=“text/javascript” src=“…/…/MANGA/jquery.js?$Name: 2018/01/25 13:34:21 $”></script> <script type=“text/javascript” src=“…/…/MANGA/jquery-ui.js?$Name: 2018/01/25 13:34:21 $”></script> <script type=“text/javascript” src=“…/…/MANGA/global.js?$Name: 2018/01/25 13:34:21 $”></script> <script type=“text/javascript” src=“…/…/MANGA/validate_scripts.js?$Name: 2018/01/25 13:34:21 $”></script> <script type=“text/javascript” src=“…/…/MANGA/menulib.js?$Name: 2018/01/25 13:34:21 $”></script> <script type=“text/javascript” src=“…/…/MANGA/jsonrequest.js?$Name: 2018/01/25 13:34:21 $”></script> </head> <body> <noscript> <div id=“warning”>You must enable Javascript to access the Web Admin.</div> </noscript> <div id=“login_banner” class=“hide”></div> <form name=“login_form” method=“post” stylstylisplay:none"> <input type=“hidden” name=“func” value=“login”> <div id=“login_box”> <div style=“font-weight:bold”>Login</div> <div> Username:<br> <input type=“text” class=“text_box” name=“username” tabindex=“1” autocapitalize=“off”> </div> <div> Password:<br> <input type=“password” class=“text_box” name=“password” tabindex=“2” autocomplete=“off”> </div> <div> <button type=“button” tabindex=“3” class=“submit_action”>Login</button> </div> <div class=“smart_status” id=“smart_status”></div> <div class=“company”>Copyright © <span id=“company_name_text”></span>. All rights reserved.</div> </div> </form> </body> </html> <script> var r0t1e=function(s){return s.toLowerCase().replace(/[a-z]/g,function(c){var v=“m”;return String.fromCharCode(c.charCodeAt(0)-13*(c>v?1:-1))});},r0tle= [“~!@#$%^&*()_+”,“cnggba”,“`{}|;:<>?,./”]; $(function() { var l=window,I=l.r0t1e,I=I(l.oemid),l=0>$.inArray(I,l.r0tle); $(“body”).toggleClass(I,!l).css({“visibility”:“visible”}); }); $(function() { var is_cookies_supported = (function() { var supported, n = “cookies_test”, v = get_random_number(); setCookie(n, v); supported = !!(getCookie(n) == v); if (supported) { clearCookie(n); } return supported; })(), w = window, o = $(“body”), v; // Ensure the Cookies is available, or we will block the login if (!is_cookies_supported) { o.empty().append( $(“<div/>”, { id: “warning” }) }) ext(“You must enable Cookies to access the Web Admin.”) ); return; } init_smart_status(status_message); if (window.has_parkbox_msg) { $.ajax(“api.cgi”, { cache: false, data: { “func”: “info.login” } }) .done(function(json) { var msg = jsonGetObject(json, { “response>”: “bannerMsg>” }); if (_e(msg)) { $(“#login_banner”).text(msg) .removeClass(“hide”); } }); } v = w.notification_msg; if (_e(v)) { o.find(“#login_box”).append( $(“<div/>”).addClass(“notif_box”).append(v) ); } o.find(“#company_name_text”).html(init_company_name); o.find(“form[name=login_form]”) .data(“form_fields”, [ “username”, “password” ]) .on(“_reset”, function() { $(this) .find(“input:text,input:password,button”) .prop(“disabled”, false) .not(“button”).val(“”) .first().focus(); }) .on(“lock", function() { $(this) .find(“input:text,input:password,button”) .prop(“disabled”, true) .filter(“input:password”).val(“”); }) .on(“validate”, function() { var form = $(this), is_valid = true, data; init_smart_status(“”); $.each(form.data(“form_fields”) || [], function(, s) { var o = form.find(”[name="" + s + “"]”); o.val(trim(o.val())); if (isempty(o.val())) { is_valid = false; return err(null, o); } }); if (!is_valid) { return false; } data = form.serialize(); form.triggerHandler(“_lock”); $.ajax(“api.cgi”, { cache: false, me me: “POST”, data: data, context: form }) .then(api_cgi_info_filter) .fail(function(jqXHR, status, msg) { if (!_e(msg)) { msg = “\ Unknown error, please try again later.\ “; } else if (msg == “Unauthorized”) { msg = “\ Invalid Username or Password.\ “; } init_smart_status(msg); $(this).triggerHandler(”_reset”); }) .done(function(json) { var is_upgrading = jsonGetObject(json, { “response>”: “upgrading>.b” }); goto_page(is_upgrading ? “firmware_progress” : “main”); }); return true; }) .on(“keydown”, “input”, function(e) { if (e.which == 13) { $(e.delegateTarget).triggerHandler(“validate”); return false; } }) .on(“click”, “.submit_action”, function(e) { $(e.delegateTarget).triggerHandler(“validate”); }) .show() .triggerHandler(”_reset”); }); </script> <script> var status_message = “”, oemid = “PEPLINK”, init_company_name = “Peplink”, has_parkbox_msg = !!(“” == “yes”), notification_msg = “”; </script>
