Hello everyone,
I received a new Balance One today and was excited to get it up and running.
But I noted some strange behaviour. The Balance One does drop the WAN port/connection randomly. I can see a “No cable connected” in the event log. Occasionally I see a “DNS healtcheck failed” error, when I change settings and sometimes I can see a reboot for no reason.
This is behaviour is more likely to happen, when I run some speed tests.
It’s connected to a FRITZ!Box 6490 Cable which is used by my ISP to setup cable internet. It’s set to static ip.
The FritzBox does not have any events or drop-outs and it is used with another router (which i wanted to replace with the Balance One) without any problems.
Any ideas or settings i can/should test?
Firmware 7.0.2
Thanks and regards
