The firmware 5.4.4 is now available. In this new update, we have added a new chart to give you complete visibility of your SpeedFusion connection. Featuring also a range of important improvements and SpeedFusion stability enhancement, firmware 5.4.4 is an essential update to your existing Balance and MAX deployment. Try out the new firmware today at http://www.peplink.com/support/downloads/.
We have identified some stability issues in Firmware 5.4 series and decided to remove it temporarily from our download sites for further investigation. The issues could affect Peplink devices with heavy firewall logging enabled, and may cause inaccessible web UI over a few days of use.
Advice
For Peplink devices already running on 5.4.1 to 5.4.4, you are advised to check and turn off all firewall logging options. If your device is running fine, you can stay with 5.4.x and wait for our next update. If you experience issues with 5.4.x, you can either download and install 5.3.12 or contact us for support.
