Balance as a local gateway
Hello together,
could someone help me with the following question?
I have a Balance 20x which I install in an existing LAN, as an example 10.11.12.0/24. The Balance gets the 10.11.12.13 on the WAN adapter. Is there a possibility to set a route from the existing LAN to the 10.11.12.13 and the Balance passes on the traffic to the PepVPN with suitable outbound polices? The traffic should preferably be on a Pep internal IP NAT, so that I do not have to take into account the existing LAN 10.11.12.0/24.
I have tried it with the drop in mode, but here the local IP from the LAN is always given and I have not been able to build a NAT for this.
Does anyone have any ideas?
Thanks a lot
Janos
