Balance 380 VLAN
Hi Guys
I need to setup VLAN’s so that my different IP subnets route out via multiple gateways.
192.168.49.0/24 GW 192.168.49.1 - Wifi devices
192.168.48.0/24 GW 192.168.48.1 - PC’s
192.168.47.0/24 GW 192.168.47.1 - VOIP phones
192.168.46.0/24 GW 192.168.46.1 - Wifi Guest
Is this possible and how do I go about setting it up?
Hi @Gavin_Pitt,
Yes, this is possible.
You can configure VLAN’s under ‘Network’ > ‘Network Settings’, in the web admin interface.
In some older firmwares you will have to enable VLAN manually.
You can see how in the following example:
You will have to click on the blue question mark (?) to find the ‘press here’.
It should look like this after enabling VLAN or upgrading your firmware version:
Thanks, Is it possible to do this without using VLAN ID’s as we have some old Layer 1 switches etc?
Hi @Gavin_Pitt,
This should be possible with most Layer 1 switches, but not all Layer 1 switches support this.
You’re better off buying some new Layer 2 switches, this will surely support it.
Your WiFi accesspoint(s) will need to support multiple SSID’s with VLAN support.
