Balance 380 and point to point internet
We are switching to a routed internet connection where we will have a point-to-point (/30) connection to our provider and a separate ip subnet for our computers and servers. Will the balance 380 handle this type of configuration? How would I set this up?
Thanks, Shen
Just to check whether you require NAT for the Point to Point WAN connection ?
If you require NAT for the WAN interface then you can define the separate IP subnet as “Additional Public IP Settings” for the WAN. For more information, please refer to the attached screenshot:
After defined the “Additional Public IP Settings”, you can use NAT Mapping or Inbound access for the Inbound traffics or outbound traffics NAT.
Else if you only require routing for the WAN connection, you can enable IP forwarding for the Routing Mode.
Thank You
