One of our three managed PepLink Balance 310 devices keeps restarting itself.
The restarts occur in quite a high frequency:
Fri Dec 06 04:19:10 CET 2013
Fri Dec 06 08:59:01 CET 2013
Fri Dec 06 16:16:47 CET 2013
Fri Dec 06 17:44:03 CET 2013
Fri Dec 06 21:41:00 CET 2013
Between restart #4 and #5 the Firewall setting Intrusion Detection and DoS Prevention has been changed from “Disabled” to “Enabled”.
The Operating Environment seems well within range:
Temperature minimum last 24 hours was 22,5 °C and 25,0 °C was the maximum.
Humidity minimum last 24 hours was 26,7 % and 38,2 % was the maximum.
Firmware: 5.4.9 build 1564
Hourly data rates are up to 8.7 GB.
Daily traffic rates are up to 139 GB.
Monthly traffic rates are up to 3 TB.
What can be done to prevent this frequent number of restarts?
Would you please remove Application QoS rule for “All Supported Streaming Applications”, “IPsec” and “PPTP”? The default priority is normal and these three rules are not necessary. But we found that this may causes the reboot issue. Please remove these three rules and see weather the issue can be solved or not.
After removing all QoS rules the spontaneous reboots occur at larger intervals, but the first one did already occur after approximately 9 hours: Sun Dec 15 10:56:37 CET 2013.
After a second try, the Firmware upgrade to version 6.1.0 succeeded.
But after reboot I am locked out: “You need to unlock your new firmware before it can be fully functional.”.
After the Balance 310 firmware upgrade to version 6.1, our watchdog monitoring (ICMP, 10 second interval, 9 ping retries) detects that the Balance is not answering any of the ICMP request within the 90 second interval. This interval was also used with version 5.x firmware.
Watchdog monitoring is now increased to a 15 second interval and 14 ping retries, before powering off, waiting 10 seconds and powering back on the BA-310.
Even running firmware 6.1.0b19 build 2457 one out of three Peplink Balance 310 hw v2 devices keeps rebooting at random (with the external watchdog disabled).
Quote: …the Balance router stops transmitting SIP packets for 1 specific provider (configured 3 times) every 13 days. And even after the Peplink 300 has been cold booted within the last hour, the BA300 reboots itself, after a 1m25s phone call using the voipbuster service…
